Codes ERREUR Yamaha EFI
Posté le 13 octobre, 2015 - 12:41
6227 lectures
1 commentaire
    http://www.capbreizh.com/bricolage/YDS/YDS_Operation_Manual.pdf
  Par exemple   page  24  le Code  49  signifie   :    Over cooling  =  Sur rafraîchissement =  Thermostat Bloqué  Ouvert
  Cela correspond à la Fréquence du voyant  qui   s'allume 4 fois, une pause et 9 fois
  Donc  Code  49    =   4 fois   pose   et  9 fois
  DIAGNOSIS
The diagnosis codes of malfunctions recorded in the outboard motor
 ECM, the diagnosis codes
Code Item
13 Pulser coil
14 Crank position sensor
15* Water temp sensor
15* Engine temp sensor
17 Knock sensor
18 Throttle position sensor
19 Battery voltage
22 Atmospheric press sensor
23 Intake temp sensor
24 Cam position sensor (EXH)
25 Fuel press sensor
26 Injector
27 Water in fuel
28 Shift position switch
29 Intake press sensor
37 Intake air passage
39 Oil press sensor
44 Engine stop lanyard switch
45 Shift cut-off switch
46 Overheat thermoswitch
49 Over cooling
59 Memory data
62 Fuel pressure too low
68 Variable cam timing (STBD)
69 Variable cam timing (PORT)
71 Cam position sensor (STBD INT)
72 Cam position sensor (PORT INT)
73 Oil control valve (STBD)
74 Oil control valve (PORT)
83 Trim/tilt sensor
85 ION detection module
86 Immobilizer
112 - 119 Electronic throttle system
121 - 123 Electronic throttle system
124 - 128 Throttle position sensor
129 Electronic throttle system
131 - 135 Accelerator position sensor
136 - 139 Electronic throttle system
141 - 145 Electronic throttle system
146 - 150 Shift position sensor
153 - 155 Shift position sensor
156 - 157 ENG-R.C. communication
160 - 181 Remote control system
183 - 184 Remote control system
186 - 187 Remote control system
1 commentaire(s)
  • Kerlouzou
    Kerlouzou
    Le 26 juin, 2024 - 18:12
    Que signifie code erreur 186 ?
