Cablage yamaha 85 cv
themask
Message par themask »
Bonjour, je suis a la recherche pour un ami du plan de cablage d'un HB yamaha 85cv , afin de rebrancher toute l'instrumentation
Merci pour lui
franck2B
Message par franck2B »
Pas de schéma à te proposer, mais une liste en anglais :
BLACK = Ground
RED = Battery Positive; SW3 Oil warning red light V4
YELLOW = Ignition ON 12-volts; Four-stroke lighting coil
BLUE = Instrument lights, choke, choke circuit, Ground potential oil transfer, High speed Charge Coil
GREEN = Tachometer signal, lighting coil lead, knock sensor
ORANGE = Trim position sensor
PINK = Oil and overheat signal ground
WHITE = Ignition stop circuit, SW1 oil transfer off position V4
BROWN = Start circuit Low speed charge coil; Positive "+" potential to oil transfer pump; SW2 transfer on position V4
GRAY = Warning circuit lead; Over-rev. control; Four-stroke tachometer
SKY BLUE = Trim up
LIGHT GREEN = Trim down
YELLOW/Red = Diagnostic lead from ECU
PURPLE = ECU groud to enrichment solenoid V76
BLACK/Yellow = Thermo sensor
BLACK/Red = Remote oil tank ground return, PBS to tachometer, Low speed charge coil
BLACK/White = Ignition coil primary lead
GREEN/Blue = Crank position sensor
GREEN/Red = Red oil warning light ground through SW3 in main tank oil sensor to tachometer
GREEN/White = Crank position sender; Lighting coil lead to rectifier
BLUE/Green = Main tank oil level sensor SW2 oil transfer circuit
BLUE/Red = Main tank oil level sensor SW3. No oil warning circuit
BLUE/White = Main tank oil level sensor SW1; Oil transfer OFF circuit
BLUE/Yellow = Shift cut switch
PURPLE/Red = OX66 #1 injector
PURPLE/Black = OX66 #2 injector
PURPLE/Yellow = OX66 #3 injector
PURPLE/Green = OX66 #4 injector
PURPLE/Blue = OX66 #5 injector
PURPLE/White = OX66 #6 injector
RED/Yellow = Key on power through fuel relay pump; power to ECU; Fuel pump and fuel injectors
WHITE/Red = #1 pulser V6
WHITE/Black = #2 pulser V6
WHITE/Yellow = #3 pulser V6
WHITE/Green = #4 pulser V6
WHITE/Blue = #5 pulser V6
WHITE/Brown = #6 pulser V6
YELLOW/White = Electric fuel pump for electric carb system (ECS)
Je te laisse le soin de la traduction :lol:
themask
Merci pour ta reponse ; ça nous aide deja beaucoup :wink:
themask
Heu Franck , c'est un modele a 3 carbus, sur ce que tu m'as envoyé c'est injection ça change quelque chose ?
franck2B
Non, rien. Tu oublies la partie injecteurs :wink:
themask
Merci :wink:
